Hi, I am using Revit 2021. I wanted to create new family door and model it but I couldn’t find Metric Door family in family library. I downloaded US Metric families from Autodesk page but still can not find M_door
If you have downloaded the Content library to the default location the templates should be found under the following directory
C:\ProgramData\Autodesk\RVT ####\Templates
In your case replace the RVT 2021
I have downloaded those templates, I have them but I can not find M_door in them
Hi, I downloaded templates from here but in there I can not don’t that M_door family. That is the problem
Are you searching for the door template (.rft) or the OOTB door families in the library (.rfa)?
If it is the template you are looking for, then you should look/search for Metric Door.rft not M_Door
there is no M_door name in the library just look for the door with .rfa extension? thanks
