Metric and Imperial template revit 2024
104157832
104157832
I've installed Revit 2024, in new project section, there is no Imperial and Metric template...!
syman2000
Check this site to download the 2024 template content
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Thank you, but I need to have the Imperial and Metric Architectural templates in this section. in the new project template. I've attached the picture below. As you can see there is no metric, Imperial architectural, and...
RobDraw
This is what I got with a fresh install of '24.
Rob
Hi thanks for your response, but I need to have the Imperial and Metric Architectural templates in this section. in the new project template. I've attached the picture below. As you can see there is no metric, Imperial architecture, and...
