message in nested family
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
peter__smith
276 Aufrufe, 4 Antworten
In the nested family there is a message “DIN-R” in shareparameter “DIN”, see “property” of the highlighted openable part of the window.
Question:
How can I take over / transit this message in this window family, because I want to use this message in the schedule?
Kind regard,
peter smith
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: peter__smith
@peter__smith
If you want it to be scheduled for the Main family then you will need to redo/replicate this y/n drill in the main family.
  • add 2x Yes/No
  • add a text instance shared parameter = if(DIN-R, "DIN-R", "DIN-L")
  • then you associate the DIN-R and DIN-L from the Nested family to those you created in the host
If you prefer a GIF to watch, you will need to attach the family in question
Nachricht 3 von 5
peter__smith
Thx, I just tried, but I don't get it.
I think a GIF will be easier for some explanation. I just attached a rfa-file in attachment.
thx in advance.
Nachricht 4 von 5
RDAOU
@peter__smith
See below GIF
(Either make both Y/N and the DIN text parameter as Type Parameters OR all as Instance)
Nachricht 5 von 5
peter__smith
Thx. I get it, finally.
It took time to set up the right configuration.
Thx.
