How do you merge a MEP.rvt model with an arch .rvt modle
Gelöst! Gehe zur Lösung
Gelöst von natasha.l. Gehe zur Lösung
To what end?
Do you really want to combine the individual models into a single model?
MEP model lacks all walls, etc....yes, need to display both at least to some degree. walls and electrical devices in one model would
be great
Hi @travisARFQA
I see that you are visiting as a new member! Welcome to the Autodesk Community!![]()
Let me know if you have any other questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
MEP, any models that come from other departments or from consultants, are always linked and not merged into the architecture model. That helps to keep everyone's work, responsibilities, and accountability separate, also keeps the model in good health and manageable.
Hi @travisARFQA
Please see the video below on merging models.
Let me know if you are able to resolve your issue.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Viveka CD
Hi @travisARFQA
I just wanted to follow up here, any progress on this issue?
Do you mean A360?
Glue is one of the products, BIM360 is the brand with many products.
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
Hi @travisARFQA
I did not see the subscription information attached. Can you re-send and please post to the Installation and licensing forum?
Our specialist @natasha.l should be able to help you with your subscription questions.
Viveka CD
You will need to have BIM360 Glue installed to merge models.
Viveka CD
Thank you @Viveka_CD, I can try to provide some more information.
Hello @travisARFQA,
I have reviewed the posts above & the products you have available in your account. You currently do not have BIM 360 "Glue", I know this can be confusing, but BIM 360 Team is a separate product from BIM 360 Glue. https://www.autodesk.com/products/bim-360-glue/overview.
You would need to purchase BIM 360 Glue or try the 30day Trial. Please visit click here to purchase BIM 360 Glue or visit the Locate an authorized Reseller site.
Thank you for posting. ![]()
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank you @natasha.l ![]()
Viveka CD
