merge two curved walls into one single wall
Message 1 of 8
How can I merge two curved walls into one single wall. With a straight wall, all I have to do is pull one of the walls back and then pull it to the other wall and it will merge into one wall automatically. However, with two curved walls I cannot do that.
please see images
Would really appreciate the helps. Thanks
Replies (7)
Message 2 of 8
martinTstewart_Adsk
Autodesk Support
Autodesk Support
In the example you provided, assuming the curves are the same wall type, I'd delete one and extend the other to the end.
Does that work?
Martin Stewart
AEC Support Specialist
Message 3 of 8
Lance.Coffey
Autodesk Support
Autodesk Support
I am not finding a way to merge two curved walls together. I suspect that this is to protect against situations where an unbroken circle could be created.
Here is a video with more info on this topic:
As I mentioned in the video, you could post this Idea (to allow merging of curved walls) to our Ideas Page.
Lance Coffey
Technical Support Specialist
Message 4 of 8
BIMologist_
In revit the curves are treated different than straight segments. While it is easy to join straight segments , curves will not join as you are wanting. As Martin suggested to delete one and extend the other curve. Not ideal I know.
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
Message 5 of 8
Thanks for your reply
I want know if there is a possibility of merging/joining them into one
without having to delete one of them
Message 6 of 8
Your video was very informative. Thank you very much
Message 7 of 8
Thank you everyone for your input. I am a new revit user and find the community here very helpful. Thanks
Message 8 of 8
Andres_MedinaMB
I have the same issues but for straight walls, where both have doors, so I need/prefer just to join them instead of deleting them. Any suggestion on how to do this?
