mental Ray settings in Revit
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
874 Aufrufe, 1 Antwort
Hi there
Trying set mental ray in my Revit render settings but it doesn't show..see attached screenshots
1 ANTWORT 1
Nachricht 2 von 2
Kimtaurus
als Antwort auf: Anonymous
If I recall correct Autodesk dropped the Mental Ray renderer in R2017 and R2018. The screenshot you show with Mental Ray is from a R2016 version.
Currently Revit uses Raytracer to render.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-C8772A85-D53B-463B-AD11-49D8FC9877BD
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-FEA68D9E-23D8-4021-A675-7FFA58ACB49D
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
