Membrane layer: Visualization
3 ANTWORTEN 3
Nachricht 1 von 4
XXalessio.amodioXX
651 Aufrufe, 3 Antworten
Hi all,
For Builiding Permit I prefer model finishes as membrane (To not mess with dimentioning) and at the same time having good elevation color rapresentation.
This trick worked for Ceiling but not for wall.
Any Idea?
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: XXalessio.amodioXX
you can't unless use paint to colour. you can refer to this previous thread and see if helps. thanks
Nachricht 3 von 4
XXalessio.amodioXX
als Antwort auf: ennujozlagam
That is a pity because with ceiling it works.
Nachricht 4 von 4
ennujozlagam
i inderstand what you mean.
Two kinds of ceilings can be placed in your model, basic ceilings and compound ceilings. Basic ceilings are planar elements with no thickness. Surface material patterns can be applied to the basic ceiling plane. Compound ceilings are composed of layers with a material thickness defined to each layer.
