Mechanical duct work does not show up on architectural RCP
10 ANTWORTEN 10
Nachricht 1 von 11
PETANJLGW
1368 Aufrufe, 10 Antworten
Could someone please help me figure out how to show mechanical ductwork in an architectural RCP.
-Mechanical in on in visibility settings
-Ductwork is 2420 to bottom of duct. The cut plane is set to 2600
-I can see the duct in 3d and settings/elevations
Thank you
10 ANTWORTEN 10
Nachricht 2 von 11
AutoCAT95
als Antwort auf: PETANJLGW
You should also check:
- whether the ducts are modeled on different hidden workset
- show hidden elements on particular view
- visibility graphics (VG) -> Ducts
- view range (VR) if the ducts can be below or above particular level
Nachricht 3 von 11
bin
Is 2600 your cutting level? And your duct is lower than that?
Nachricht 4 von 11
FWIW: RCP View Range is "backass backwards" from Plan View Range.
Nachricht 5 von 11
RobDraw
als Antwort auf: barthbradley
Also, once the cut plane is set correctly the ductwork will be shown with the ducts in top hidden.
Rob
Nachricht 6 von 11
als Antwort auf: RobDraw
How so Rob? I know this is your field of expertise. What am I missing?
Nachricht 7 von 11
RobDraw
With the RCP view set to hidden line, the higher ducts get hidden lines. The opposite of what you see in plan view.
Rob
Nachricht 8 von 11
PETANJLGW
Hi
If my ductwork is 350mm dia. The ceiling height is 2700mmH and the ducts are sitting 50mm below the ceiling what should I set the below to:
Primary Range:
Top
Cut Plane
Bottom
View Depth:
Level
All I se in the RCP currently is a single line for the duct work as opposed to the actual dia of the duct.
Nachricht 9 von 11
Set to Medium or Fine Detail Level
Nachricht 10 von 11
RobDraw
@PETANJLGW wrote:
Hi
Primary Range:
Top
Cut Plane
Bottom
View Depth:
Level
If you see the duct then the view range is not the problem, is it?
Rob
Nachricht 11 von 11
ftruslow
Your problem may be that your view or categroy detail level is set to coarse.  Also when in architectural RCP, yuor cut plane must be set below the CENTERLINE of the duct, or the straight duct sections will not show.  the fittings do but not the straight runs.
