measuring the angle between two faces
2 ANTWORTEN 2
Nachricht 1 von 3
1412 Aufrufe, 2 Antworten
Dear forum,
I like to kwow if there is a solution for measuring the angle between two faces simply to select the two faces end then you can see the result.
Thsi is very handy if you want to know to cut a panell on a sawing machine.
Thanks in advanced.
Best Regards
Chris van der Haar
2 ANTWORTEN 2
Nachricht 2 von 3
constantin.stroescu
als Antwort auf: Anonymous
you have to use as Work Plane, a Perpendicular Face or Perpendicular Reference Plane on the Intersection Line between the two Faces that contain the Angle.
Constantin Stroescu
Nachricht 3 von 3
constantin.stroescu
the Intersection Lines Between the Faces and the  Reference Plane Left-Right (in this case) are not necessary , but I draw them for a more clear graphic presentation...
Constantin Stroescu
