I need to drag out the dimension shown i the screencast below. The measure is needen in a formula, and need to work with my family created by parameters. Anyone has an idea?
Gelöst! Gehe zur Lösung
Gelöst von vancikv. Gehe zur Lösung
Maybe you need a reporting parameter? https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-M...
Not a clear explanation. Can you elaborate? Maybe post some more illustrations? Maybe even post the family (rfa) you are working on?
....you know, I'm thinking you could use some trigonometry formulas to get where you want to go. See "Trigonometry for Right Triangles" in this link:
Thanks @barthbradley. I tried with trigonometry, but reporting parametres, was the simple solution. Thanks anyway.
