Hi to all as title I've trouble to selecting single pannel after dividet the curtain wall with curtain grid.
I follow the lesson in unit 4-11(learning path for certification) but when i try to select the pannel to make a door ,all the wall are selected, I've saw many time the video tutorial and I've tried to make a new wall with the same passeges but the result are the same.
I use 2022 version in demo mode
Tnx for any help
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Go to the 3D view >> Hover Mouse over the Panel >> and press TAB key on the keyboard until you highlight the Panel >>> once it highlights, click the left mouse button to Select it...
If that doesn't work ... let us know to suggest further
