Maxwell Rendering
Maxwell Rendering
Maxwell Rendering
I installed the maxwell render add-in on revit and it is under the add-in tab but is light gray (not clickable). I also attached a picture so you can see what exactly what I'm talking about. Any reason why this is and how to fix it? Thank you
ennujozlagam
hi, Due to a limitation in Revit itself, this panel is only active in the main view. Moving to an alternate view created via a camera or a walkthrough will disable the plugin bar and you won't be able to access any feature until you press the Default 3D View button in the Revit View tab.
hope it helps. thanks
It worked when I went to 3d view. Thank you for your help!
ennujozlagam
hi, your welcome. if your issue is solved, please close this issue and mark as solution and if your are happy give kudos. thanks
