Maximized Revit Clipped All Edges
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
tkrejci
275 Aufrufe, 5 Antworten
This happening to all versions of Revit but no other application.  When I maximize Revit, it fills the screen but seems to go beyond the monitor edge by several pixels leading to the interface being cropped.  From the image below, you can see that the title bar is clipped off as well as the bottom.  From a 2nd monitor, it appears a couple of the pixels oozed from the edge onto it.  This happens ONLY with Revit (2021-2024) and no other application.
Thank you!
5 ANTWORTEN 5
Nachricht 2 von 6
SteveKStafford
als Antwort auf: tkrejci
Are you using a Display Scale greater than 100%. This depends heavily on your graphics card and multi-monitor support and if Revit supports the card/driver. What does Revit report in the Hardware tab of the Options dialog (File ribbon tab > Options > Hardware)?
Steve Stafford
Nachricht 3 von 6
tkrejci
als Antwort auf: SteveKStafford
No, scale is set to 100% on both monitors.
This only seems to affect Revit with the clipping. However, some dialog boxes in Outlook have parts of buttons that are off the edge. It's like some programs are using the same kit of parts for the graphic elements and someone has replaced some of those parts with parts that are at a different scale and don't fit with the rest of kit.
Thank you
Nachricht 4 von 6
SteveKStafford
Interesting, I find Bluebeam slips beyond the screen boundary here but Revit plays along. Are your screens using the same Aspect Ratio, resolution? If they are different that might account for it?
Steve Stafford
Nachricht 5 von 6
tkrejci
Thanks for the reply.
I have rebooted again and I changed PaddedBorderWidth under Computer\HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics and-for the moment-it's back to normal.
We'll see how long this lasts.
Nachricht 6 von 6
SteveKStafford
Okay, good luck!
Steve Stafford
