Matrials of Autodesk dos not availale
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
486 Aufrufe, 7 Antworten
I used Revit 2018 material such Masonry doesnot available, even in search there is no autodisk material
I installed materials
thanks
7 ANTWORTEN 7
Nachricht 2 von 8
baniabdelwaheb1
als Antwort auf: Anonymous
Maybe Material Library is not installed.
To verify,  go to Control Panel > Programs and Features. Scroll down and look for the Autodesk Materials Libraries.
Make sure you have rights to access the Material Library.
Check to see if the problem persists by opening  Revit with Administrative rights.
If the Materials Library is listed, try repairing it.
If it is not listed, you should be able to reinstall the Material Libraries.
If they still do not show up, perform a clean uninstall and reinstall of Revit.
Nachricht 3 von 8
I don't believe there is a "Masonry" Material, but there is a boat-load of Assets that come up when you search "Masonry". Any one of those could be assigned a New Material, named anything you want.
FWIW: https://blogs.rand.com/support/2015/09/revit-creating-a-new-material.html
Nachricht 4 von 8
als Antwort auf: baniabdelwaheb1
yes there is material list in control panel and I uninstall material then
re installed the same problem appear, see figure 1 is my revit and figure 2
of others
in my revit 2018 Autodesk material is not available
Nachricht 5 von 8
als Antwort auf: barthbradley
thanks a lot, but the problem in my case when search for this material it doesnt show any material??????
Nachricht 6 von 8
Notice where I am searching?  Assets.
Nachricht 7 von 8
please how can I do that, I search in search field, thanks4.JPG search field
Nachricht 8 von 8
Thanks a lot dear I can find it, my problem is about to be solved
