materials
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
344 Aufrufe, 5 Antworten
materials
I do not know why but in my current project file that I am working on I cannot change the pattern of brick and tint. It works in new file that I created separately.  I am trying to simply change Brick Common to another brick pattern and tint. Is my file corrupt? What am I doing wrong? Attached is the file. I looked into phasing but that does not seem to be the issue.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Nachricht 3 von 6
DEJA VU! Or...expecting different results by doing the same thing over and over again?
@Anonymous, you, yourself, already determined yesterday that this issue was only happening with this ONE project file. You, yourself, said that you couldn't replicate the issue in a new project. And since none of us, including Toan, could replicate the issue either, using YOUR problem file, I would logically suspect that the issue you are having with this ONE file is due to a "loose nut behind the keyboard".
If you have to use this ONE file; copy it's elements into a new project template. Problem solved! "Genius" if I do say so myself. HA!
Nachricht 4 von 6
als Antwort auf: ToanDN
yes, i did. thank you for your help. i followed your advice and changed visual style to realistic. my message was posted again somehow. sorry, i am new to this forum.
Nachricht 5 von 6
als Antwort auf: barthbradley
sorry about this my previous message got re-posted for some reason. i am still trying to figure out how to use this forum. thanks to toan's advice i did end up solving the problem a few days ago. however, your last message sounds a bit rude and condescending. "loose nut behind the keyboard" is not a very nice thing to say to someone who is seeking help in this forum. pls watch your netiquette. thank you.
Nachricht 6 von 6
Mariya, you're quite right...I can see how you could take my remark as being rude, rather than jovial - which is how I intended it. I apologize.
Welcome to the forum!
Cheers!
Barth
p.s. "Loose nut behind the keyboard" is a funny and commonly used retort -- always delivered with tongue in cheek. And, believe me, I've been that "loose nut" many a times.
