Materials Takeoff
Materials Takeoff
anarie
Materials Takeoff
anarie
I've created a materials takeoff, and I realized that the quantities for my custom materials in an assembly are present, but the name of the material doesn't show up. So any of the standard Revit materials that I used to create a wall, maybe cast-in-place concrete for example, are listed with the name of the material then the area and volume. But with my custom materials, I have the area and volume, but not the name. Does anyone know what's going on here and how to fix it? Thanks!
You haven't named your custom materials is my guess. What is the parameter field name (for the column it's blank in) ?  Is that parameter field in your custom material filled in?
anarie
I didn't realize there was a second place to name my material, but that was definitely it. Thank you!
