Materials - Revit for student
37 ANTWORTEN 37
GELÖST
Nachricht 1 von 38
1682 Aufrufe, 37 Antworten
Good morning, sorry for the trouble but I would have a question.
I've downloaded the version for Revit students recently but when I try to go to materials to modify them I do not do it; is it a limitation for students or is there something wrong?
Thank you so much to anyone who will respond
37 ANTWORTEN 37
Nachricht 2 von 38
-FDC-
als Antwort auf: Anonymous
Something is wrong.
What version did you download ?
Check the autocad desktop app if there are any updates.
Can you post a screenshot so I can understand the problem ?
Nachricht 3 von 38
Stanis-74
recently i`ve had same problem, but it was with buttons of family panels.
try replace your file to other derectoriy. or check box "read only" in your file options.
Nachricht 4 von 38
als Antwort auf: -FDC-
I installed Revit 2018.
I did a photo of the files that I installed; I do not know how to get the picture of the problem because when I try to press on the material button it does not do anything so i do not know how to make you see
Nachricht 5 von 38
als Antwort auf: Stanis-74
thanks for your advice  but I tried to press everything ... nothing to do :enttäuschtes_Gesicht:  I think I will try to install it again
Nachricht 6 von 38
Stanis-74
Nachricht 7 von 38
Thanks for the photo but even if I do the steps you have shown me, after pressing on the "ball" materials I will not leave the screen that came out with you with all the materials; it's as if the material library did not exist
Nachricht 8 von 38
Stanis-74
did you create a project ?
Nachricht 9 von 38
Yes
Nachricht 10 von 38
-FDC-
What graphics card do you have and did you install the latest drivers?
Nachricht 11 von 38
Stanis-74
find same problem here: https://www.youtube.com/watch?v=lPpd6G5JIMs
the autor has fix the problem by uinstal and instal libraly pack
Nachricht 12 von 38
my mount NVIDIA GEFORCE 610M, I did upgrade 2 days ago
Nachricht 13 von 38
my pc*
Nachricht 14 von 38
-FDC-
You also installed the latest nvidia drivers ?
Nachricht 15 von 38
-FDC-
If you are sure you have the latest nvidia drivers try the autodesk desktop app to see if there are any updates you don't have.
If you don't have it try this link:
www.autodesk.com/ada-installer
Nachricht 16 von 38
-FDC-
If all this dosn't help try installing the latest .NET framework.
See this link:
https://forums.autodesk.com/t5/installation-licensing/windows-7-8-1-10-updates-microsoft-net-framewo...
Nachricht 17 von 38
I tried the link you sent me but says I already have the most up-to-date version, I no longer know how to try it I uninstalled and installed everything. Can not you send me the downloaded file? maybe I finally get the materials.
Nachricht 18 von 38
-FDC-
Is it revit 2018 or 2018.2 ?
Nachricht 19 von 38
is Revit 2018.2
Nachricht 20 von 38
-FDC-
Latest .NET framework and latest nvidia installed?
Maybe you can try it with disabled hardware acceleration.
