Materials Library Just Hangs "not responding"
2 ANTWORTEN 2
Nachricht 1 von 3
588 Aufrufe, 2 Antworten
I'm using a Revit 2020.2.1 custom template and materials library, working from home, and when offline the materials browser opens fine, however, when online it just hangs "not responding"?
I've tried the Revit Architecture Template and that works fine off and online, therefore, i'm at a loss at what is wrong?
Just wondering if anybody else has had this issue or any idea of what might be going on?
2 ANTWORTEN 2
Nachricht 2 von 3
alan_eu
als Antwort auf: Anonymous
Did you try to disable your video card on File - Options - Use hardware acceleration?
Being online or offline shouldn´t be different or even on custom template files...
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 3 von 3
I have the same problem.
I have to wait about 5 minutes for anything to do with materials to load. I am using Onedrive but the file is on my C: drive. My Revit licence is via my company's corporate network accessed from home. One thing I tried was to add an "Additional Render Appearance Path" as advised by someone in an AutoDesk forum but it has not changed anything.
I also have 'Use hardware acceleration' disabled.
