Hello:
I've followed suggestions for uninstalling and reinstalling Revit 2020 as a whole and its materials libraries, but everytime I get the error "source file not found: autodesk appdata\local\tem\temp5_autodeskmateriallibrary2020.zip\autodeskmateriallibrary2020...verify the file exists..." when trying to install the primary materials library file "MaterialLibrary2020." This happens with the antivirus on and off, and the folder is obviously downloaded and available for install. Please fix this bug. Did not have it with 2019. This is the student license. Did not have this issue with AutoCAD either. Please develop a patch or the like. None of the suggestions on your forums have worked, so I'm posting this issue here.
thanks.
@Anonymous wrote:Please fix this bug. Please develop a patch or the like.
Why do you think it's a "bug"? Maybe it's a loose nut behind the keyboard? Have you considered that? ![]()
BTW: We don't do "patches or the like" here. This is a Revit USERS Forum.
A better place for you to post would be here:
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
