I imported some dwg objects into Revit and assigned to them some materials.
The problem is whenever I do this in the family edition it works but whenever it gets charged into the project, all the materials are gone. Sometimes it's only some of them that disappear.
It's really frustrating, I made a lot of tests and I still don't understand what is causing the issue.
Does anyboy have an idea as to what is the issue and how I can correct this?
Thanks a lot
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Project Materials always rule the day. In other words, Material 1 in the Family may be different from Material 1 in the Project. Try using uniquely named Materials/Assets in the Family. They should carry over as is.
Do you have more than one families that have imported DWG? If so, and if the DWGs have the same layers then these same layers will share the same materials in the project. So maybe check project object styles > import category > import in families > expand to see if layers and materials assigned to them correctly.
