materials are not showing
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
elifaslikayaKKLLM
260 Aufrufe, 3 Antworten
I made a family and give it a material and pattern. But when I load it into project materials aren not showing up. I tried the fix it on the object styles but didn't worked. Probebly I made it wrong but can't fix the problem.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: elifaslikayaKKLLM
Post the family file here.
Nachricht 3 von 4
Add a material parameter in the family and assign it to the desired family elements, so then, when you load the family in the project, you can customize the material parameter in the project space.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 4 von 4
handjonathan
Hi @elifaslikayaKKLLM
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
