MATERIALS APPEARING CHOPPY WHEN ATTEMPTING TO RENDER
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
486 Aufrufe, 5 Antworten
i have my wall divided into parts, the bottom half is light grey metal panels and the top half should be consistentlREVIT MODEL CHOPPY.JPGy dark grey but it is appearing choppy when i capture a 3d view or open it in enscape. however when i open it in 3D modeling view, it appears normal. does anyone know what would cause this?
5 ANTWORTEN 5
Nachricht 2 von 6
hmunsell
als Antwort auf: Anonymous
looks like you have 2 walls on top of each other. is there a structural or other link also showing the wall too?
Howard Munsell
Nachricht 3 von 6
als Antwort auf: hmunsell
i've already checked that, there is only 1 wall there
Nachricht 4 von 6
hmunsell
that's all i had... unless you can post the model for us to look at :-).
Howard Munsell
Nachricht 5 von 6
TripleM-Dev.net
If you use Parts don't forget to only show the parts and not also the original element. (View property)
View's parts visibilityView's parts visibility
Nachricht 6 von 6
als Antwort auf: TripleM-Dev.net
that was the solution, thank you so much for your help everyone!
