How can I adjust the size of a wooden material? It looks too small, like laminate. Can you help me?
1. Go into your material browser
2. Click on the wood material you are using
3. Click on the Appearance tab for your wood material
4. Click on the image
5. A pop out window called "Texture Editor" will appear, under "Scale" you can adjust the size of the sample.
6. Increase the size of the sample accordingly
While doing the above you need to watch out for the following
There is BING AI Texture generator which you can try. There are also websites similar to the below where you can download High/Medium res images from
Architextures, the material editor for architects and designers - Architextures
Thank you, it worked, but the texture still looks a bit like laminate. I want to create a wooden façade. What should i do ?
that is because it is an imge for a wood laminate / flooring...You need to look for another image
Did you check the site I gave you? see links below
Wood Texture: Background Images & Pictures
Raw Wooden Log Facade Texture - Poliigon
