Material Takeoffs and linked phases
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
cbt990
983 Aufrufe, 16 Antworten
This is a Two phase project with Podium+phase 1 residential, then phase 2 residential. Phase 1 + 2 are linked into the Podium model. I am trying to create material takeoffs by phase.
I am filtering my schedule by phase but the quantities are reporting the same for phase 1 and phase 2:
all of these materials are in the linked projects.
It seems that the masonry and podium materials which only occur in the host model are in fact being calculated correctly. That is to say, Phase 1 with filter set to show new produces an identical schedule to Phase 2 with filter set to show complete.
Any ideas? Thanks!
Revit is amazing
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: cbt990
Have you mapped the phases between the links and the host correctly?
Nachricht 3 von 17
cbt990
als Antwort auf: ToanDN
Phases are mapped correctly. I have introduced Phase as a field and confirmed that I can see materials from both phases, when I itemize every instance:
First preference: Separate schedules by phase with total material quantities.
Second preference, one schedule with total material quantities, sorted by phase with total material quantities.
I am also trying to figure out a way to further filter elements in the schedule by workset. I am only trying to schedule walls that are in the facade workset:
but given that I don't seem to be able to filter by workset, maybe I can filter by the fact that the facade wall types all start with a certain letter?
Revit is amazing
Nachricht 4 von 17
Is you schedule phasing set correctly?  What is it?
Nachricht 5 von 17
cbt990
Again, this approach is correctly filtering elements in the host model but showing linked materials in facade walls as having the same quantity in phase 1 and phase 2, which is not correct.
Revit is amazing
Nachricht 6 von 17
cbt990
I also need to be able to filter by Wall type or workset to exclude non-facade walls.
Revit is amazing
Nachricht 7 von 17
Why don't you post the file and let us take a whack at it?
Nachricht 8 von 17
cbt990
als Antwort auf: barthbradley
It seems like the worksets and links and relevant data wouldn't be preserved when I make a copy of the file.
That said, I can produce a dummy model consisting of a very simple podium with two micro buildings if it will help problem solve.
Revit is amazing
Nachricht 9 von 17
you could always eTransmit, but whatever works for you. A mockup is fine.  Let's have a look at it.
Nachricht 10 von 17
cbt990
How can I e-transmit the mockup to you?
Revit is amazing
Nachricht 11 von 17
cbt990
Nachricht 12 von 17
cbt990
Part material takeoff for phase 2, showing complete project:
But it shows nothing if I uncheck itemize by instance.
Obviously i would like to total same materials together.
Revit is amazing
Nachricht 13 von 17
Set the schedule phase filter to Show New.
Nachricht 14 von 17
cbt990
This is more what I was trying to produce.
and I have reproduced it in the project file
But now i need it to count wall material that isn't in a part. Is there any way to count wall if part isn't available?
Or would you simply recommend making parts out of all undivided walls>
Revit is amazing
Nachricht 15 von 17
Are we going to a different topic now?
Is your question about the schedule showing the wrong phase answered?
Nachricht 16 von 17
cbt990
I think the phases are basically working now, with the schedule parameters I showed above.
What do you think about parts vs walls? @ToanDN
Revit is amazing
Nachricht 17 von 17
cbt990
I achieved what I needed to do by using a multi category schedule so I can include Wall area and Part area.
Revit is amazing
