material takeoff
5 ANTWORTEN 5
Nachricht 1 von 6
anuragkhati
413 Aufrufe, 5 Antworten
material takeoff
I have a wall that is 3.35 mt. long having a height of 3.20 mt.
So, when I take material takeoff it's coming to 10.76 m2 but when I calculate it by calculator it's coming to 10.72. So, this slight difference in decimals is acceptable, if not then what should I do to fix this?
5 ANTWORTEN 5
Nachricht 2 von 6
ralphdenhaan
als Antwort auf: anuragkhati
There can be several reasons for this, can you share a part of your model with this schedule and walls?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Material-Takeoff-s...
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 6
anuragkhati
als Antwort auf: ralphdenhaan
hi
I've shared the file.
Nachricht 4 von 6
SteveKStafford
The usual culprit is wall joining with adjacent walls. The wall length will be affected by the walls it is joined to and what kind of join is applied.
Steve Stafford
Nachricht 5 von 6
anuragkhati
als Antwort auf: SteveKStafford
so how to fix this issue?
Nachricht 6 von 6
ralphdenhaan
I've checked your model and the area is correct. The wall is 3.2052 * 3.3576 = 10.762.
So your wall is not 3.2 * 3.35 exactly.
