material takeoff
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
anuragkhati
605 Aufrufe, 10 Antworten
material takeoff
 i am this issue as my stepped stair does'nt connects to the bottom of my floor. I have my riser height is 6" and the thickness of stepped slab is of 5". Please help me on this how to  fix this
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: anuragkhati
Edit Stairs, select Stair and check the Relative Base Height under Properties. Is it greater that zero?
Nachricht 3 von 11
Wait a minute. So the Structural Depth is 5" and the Riser height is 6"; is that correct?  Well then, you need to fill that space with something.  You decide what.
Nachricht 4 von 11
anuragkhati
als Antwort auf: barthbradley
Yes the gap is of 2inches
Nachricht 5 von 11
anuragkhati
 this is the gap of 1inches and Relative Base Height is 0
Nachricht 6 von 11
anuragkhati
is there any other way ? other than filling that gap with some other material ?
Nachricht 7 von 11
Make the Structural Depth 6".
Nachricht 8 von 11
anuragkhati
but what if the structural designer design the stairs in 5" or 4" thickness and the riser height is 6" .
Nachricht 9 von 11
Look it - it ain't rocket science.  Do the math.  If the Structural Depth MUST BE 5" AND the Riser Height MUST BE 6", then you have a 1" gap.  6" minus 5" = 1".   You need to figure out a solution.  That's part of the design process. How are they supposed to install this pre-fab stair flight in the field?
Nachricht 10 von 11
anuragkhati
ok thanx.
now i got it . Structural depth and riser height should be kept same then only we would not get any gap .
Nachricht 11 von 11
What about this instead?
