Material takeoff schedule - Mass Density Data
2 ANTWORTEN 2
Nachricht 1 von 3
2240 Aufrufe, 2 Antworten
Hello everybody,
I need a solution about "material takeoff" schedule.
Even I create the building components layer by layer and define the materials, i can't see the density and mass information of the materials on the schedule.
For example, the wall has brick, insulation material, concrete etc and they are all defined by material properties in edit type section.
How can I see the defined information on the schedule as materials mass and density?
Best in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Density is Unit Weight
Create a Calculated Value for Mass = Unit Weight * Material Volume
Nachricht 3 von 3
