Material Takeoff formulas
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Mr_fr0st
335 Aufrufe, 3 Antworten
Hi, I'm pretty new to this program and I have an problem with placing a formula, when I'm creating Material Takeoff. The thing is that I cannot create a column with brick count (first picture below) and if I'm clicking OK, I will have an error (second picture). How can I solve this issue?
3 ANTWORTEN 3
Nachricht 2 von 4
emodderman
als Antwort auf: Mr_fr0st
OK, so I was able to get that to work using your formula, but once I clicked ok, it added the M^3 to my 1.1 value... Depending on your version, maybe you need to manually add that?
Also, my translation of your first screenshot lists the Type of your calculated value as Whole, but I don't know what that really might be, could your Type be wrong for the required value?
Nachricht 3 von 4
[1 brick volume] material should be Volume
Brick Quantity = (Material: Volume / [1 brick volume]) * 1.1
Nachricht 4 von 4
Mr_fr0st
als Antwort auf: emodderman
1.1 was plus 10 % from the quantity of the bricks. There was no need to add those units, right? Maybe I made a mistake, when I created unit (1 Brick Volume)?
UPD: Oh, turns out I'm a moron because I created that parameter incorrectly
