I received a Revit file which contains a main building as a model and many other auxiliary buildings, all of them as Links (Revit links)
I've just notice that when I create a material takeoff schedule, the linked objects, means the auxiliary buildings, will not be considered.
Using the "Highlight in Model" button I couldn't find one single element which relates to the linked objects!
Must I bind the linked objects, or is there something I need/have to do?
Thank you in advance.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
They do if
