material take off for amorph shapes
2 ANTWORTEN 2
Nachricht 1 von 3
bozandilistan
267 Aufrufe, 2 Antworten
I am tryin to take material take off for facade. But there is some arch extrusion and revit doesn't give the square meter properly. What is the way to get material quantity for this kinf of situations? Now i found only traditional way, manually.
2 ANTWORTEN 2
Nachricht 2 von 3
franciscopossetto
als Antwort auf: bozandilistan
Hey,
Are you sure that Revit is giving you an incorrect value? If so, you could try with Dynamo.
1. Click select.
2. Select the Facade.
3. Run.
I hope it helps,
Kind regards
Github:
https://github.com/franpossetto
Nachricht 3 von 3
I had such a case , when I had to calculate the interior surface of plaster layer of an heritage building... and I was not able to extract all the areas with Revit , so I use Dynamo for difficult surfaces ....
Constantin Stroescu
