Material Tags working in section but not plan view
4 ANTWORTEN 4
Nachricht 1 von 5
kip.larsen
354 Aufrufe, 4 Antworten
My material tags are working fine in section/elevation views, but in plan view they won't display the appropriate finish/material. In plan view they only want to display VWC-01 or VWC-02. I feel like there is an easy fix but I can't figure it out.
Thank you!
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: kip.larsen
If it is material painted to the wall surface, you wont be able to pick it with a material tag unless the wall is not vertical
Nachricht 3 von 5
kip.larsen
als Antwort auf: RDAOU
So can you tell me how to tag paint material in plan view? Is it possible
to create a generic tag that I can fill in manually with paint mark?
Nachricht 4 von 5
RDAOU
That or add a shared parameter to wall category and tag that using a wall tag
Or Alternatively, for an automated workflow you can use addins or dynamo...see below Autodesk KB Link on the same topic
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Revit-Tagg...
Nachricht 5 von 5
