Material Tag Location
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
12099 Aufrufe, 5 Antworten
Hi all.
I am trying to tag materials as opposed to families and when I click the tab it asks me to 'load' the tag. I cannot find where the material tag is located.
When I search through the annotation - tags - its not located there with all other tags.
could someone please help/ direct me to the location of the material tag?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Annotations:Architectural
Nachricht 3 von 6
ennujozlagam
@Anonymoushello if you cannot find your annotations on this folder (it depends which version you have)?  please see attached.
then you need to installled your template and libraries refer to these LINK and LINK. thanks
Nachricht 4 von 6
G.IORDACHI
als Antwort auf: barthbradley
thank you, had the same issue.
Nachricht 5 von 6
tommy-beaulieu
Same problem same solution. Thanks :strahlendes_Gesicht_mit_lächelnden_Augen:
Nachricht 6 von 6
u9401783
that great perfect...thanks
