Material Render Color
I have 2 different materials I want to be the same color, a vertical and horizontal cement board.
I know the original images aren't the same color, which I'm sure is contributing to my problem. Is there a way to manipulate the materials so the render appearance colors match?
constantin.stroescu
In such a case:
  • I' ll take both textures and work them in Photoshop so to have the same colors.
  • or , more simple, I'll make a copy of the material and I'll rotate the map of the duplicated material by 90 degrees. Then I'll have two identical materials ,one placed  horizontally and the other vertically
Constantin Stroescu
