Material references
Material references
Reed_Weinstock
Material references
Reed_Weinstock
Is it possible to figure out what families/types/elements are using a specific material? I have some duplicates and i cant figure out they are being used for and they don't show up in purge unused
ChrisBXE93T
You could do a material take-off schedule and filter by the specific material you're looking for?
EDIT: You can add the Family / Family Type as a field within the schedule to list the family.
However - if family types aren't placed in the model, these won't be in the schedule unfortunately.
handjonathan
Hi @Reed_Weinstock
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ChrisBXE93T helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
