Material Problems Tint and Brick Pattern
17 ANTWORTEN 17
GELÖST
Nachricht 1 von 18
2343 Aufrufe, 17 Antworten
hello,
tried to change brick pattern and tint on brick common and it is not letting me. i looked into phasing as well as graphics and everything seems to be fine.  i am attaching a screencast as well as the file. pls help
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: Anonymous
I'm looking at your screencast and your rvt file...I don't see where the problem is. What am I missing?
Nachricht 3 von 18
Sahay_R
BTW - I did change one of your walls to a violent pink with a different brick pattern
To change tint - Manage tab>> Materials
To actually change the material -
To change the appearance of the actual material -
Any further tweaking would need to be done in the image itself, using possibly Photoshop.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 18
als Antwort auf: Sahay_R
Thanks Rina,
The problem lies in the fact that the tint does not show and when I try to change the brick pattern to herringbone or something else it does not show either. the brick pattern always shows as "brick common" and nothing else.
Nachricht 5 von 18
There are surface pattern for hidden and shaded view and appearance pattern for rendering. You have to change both.
Nachricht 6 von 18
 it is very important that you take a look at my screencast and you will see what i mean.   i am trying to use Paul Aubin's tutorials on how to change materials. When I use this particular file, the instructions do not seem to work but when I open up a new file everything works fine. when i check off the tint tab it does not show.
Nachricht 7 von 18
That's what I'm talking about...I am able to change at my end just fine.
Nachricht 8 von 18
als Antwort auf: ToanDN
how do i do that?
Nachricht 9 von 18
So - from what you are saying - you cannot replicate this issue in another project? Is that correct? Only this one project - which I am having no issues with whatsoever.
@ToanDN: Help me out here please. Would you check out the rvt file and verify that I'm not crazy here.
edit...I'll say this: opening that file caused Revit roll-back my driver! Had to close-out of Revit and update my video driver through device mgr.
Nachricht 10 von 18
Sahay_R
Are you changing the actual material, or are you making the change I had shown in my first screenshot? Once again, I was able to change materials in your model with no problem....at the bottom of my screenshots you can see my lovely bright pink wall....
If you change the material itself - did you check the Use Render Appearance box?
Rina Sahay
Nachricht 11 von 18
Thanks for sharing that little nugget, @Sahay_R. I feel better knowing that you had no problems with the file either.
Nachricht 12 von 18
Sahay_R
als Antwort auf: barthbradley
@barthbradley Always glad to entertain! I hope you didn't miss the bit about the lovely pink wall. Violently pink would be a better way to put it.....
Rina Sahay
Nachricht 13 von 18
thanks! i don't think i am making much sense here. to change the tint please click on the tint box instead (it's on the bottom under appearance). please try to change the masonry to flemish cross. whenever i change the masonry to anything else it always reverts back to brick common.
i am not having problems with changing the colours. rather i would like to know why the tine box does not work and why my masonry always reverts back to brick common.
Nachricht 14 von 18
i am not having problems with changing the colours. rather i would like to know why the tint box does not work and why my masonry always reverts back to brick common.
Nachricht 15 von 18
genius!!!
Nachricht 16 von 18
@Sahay_R thank you both for your time. i figured it out.
Nachricht 17 von 18
well, what was the solution?
Nachricht 18 von 18
@barthbradley  I opened the Revit file just fine.
@Anonymous  Tint color works best if the texture image is in grey scale.
