material pattern
2 ANTWORTEN 2
Nachricht 1 von 3
600 Aufrufe, 2 Antworten
material pattern
hi i am facing a issue using revit 2021. when i am applying material, material pattern is not visible in revit model neither in consistent color nor in realistic mode. when i open material tab, i found a yellow error mark on materials.
kindly suggest me any solution i am attaching ralated images for more ...
thanks
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Where are you seeing this symbol? On the Appearance Tab Image(s)? Or next to the Library Folder? Post an screenshot.
Nachricht 3 von 3
als Antwort auf: barthbradley
here are some images attached with this mail for issue reference as you
asked
[image: 03..jpg]
[image: 02..jpg]
[image: 01..jpg]
[image: 04..jpg]
[image: 05..jpg]
