Material Pattern
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2415 Aufrufe, 5 Antworten
Material Pattern
I am trying to change the size of a wood plank in the pattern and I can never figure out how the formula works, no matter how many times I read the how-to. Below is the base pattern. I can see when it switches from a 2" to a 4" the only thing that changes is the "4". But when I update just that parameter to 6, 2 of the 3 vertical patterns our misaligned. I understand that the first parameter is the angle in which the line is drawn, then the next 2 are the origin, but I guess I don't fully follow the shift and pen up pen down...it never works like my brain thinks.
Thanks!
*Wood_Board_Wide, Wood: Wide boards
;%TYPE=MODEL
0, 0, 0.8, 0, 4
90, 0, 0.8, 8, 8, 4, -28
90, 16, 4.8, 8, 8, 4, -28
5 ANTWORTEN 5
Nachricht 2 von 6
Sahay_R
als Antwort auf: Anonymous
What size boards? Do you have a picture of what it is that you are trying to accomplish?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 6
als Antwort auf: Sahay_R
sorry, 6" board. same pattern, just 6". essentially it's wood plank with 6" boards of varying length. for the pattern i'd prefer to show at least 60" long. thanks.
Nachricht 4 von 6
Sahay_R
Then just two lines of code should be enough. Here is what I have for a pattern of 16x48 running bond -
*Block 16x48, 16 x 48 blocks running bond
;%TYPE=MODEL
0, 0, 0, 0, 16
90, 0, 0, 48, 24, 16, -16
Fix the numbers as you need them in Notepad, then save and change the extension to PAT.
Good luck!
Rina Sahay
Nachricht 5 von 6
hugha
To scale a fill, multiply all numbers except the first number in each line by a scale factor.
You are using:this for 4" planks
*Wood_Board_Wide, Wood: 4" Wide boards
;%TYPE=MODEL
0,   0, 0.8, 0, 4
then for  6" planks, scaling by 1.5 derives:
*Wood_Board_Wide, Wood: 6" Wide boards
;%TYPE=MODEL
0,   0, 1.2, 0, 6
90   0, 1.2,12,12,6,-42
90, 24, 7.2,12,12,6,-42
If you wish, altering the numbers in bold above changes each plank's length, currently 8*4" = 32" for the 4" planks and 8* 6" = 48" for the 6"..
You can use Excel to manage the calcs or, more simply, the fill scaling we provide in the free HatchKit Add-In for Revit.
hth
Hugh Adamson
www.hatchkit.com.au
Nachricht 6 von 6
als Antwort auf: hugha
Thanks for explaining that--hopefully this helps me figure it out for next time!
