Material Pattern: Elevation
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
XXalessio.amodioXX
985 Aufrufe, 1 Antwort
Hi all,
I am encountering some weird behaviuor of Material Pattern (Model pattern. In 3D it looks fine but not in Elevation (Seems Halftone).
NB No template,No filter,NO VG.
Any idea?
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: XXalessio.amodioXX
@XXalessio.amodioXX
A normal behavior of Model Patterns...unlike drafting patterns, Model patterns do not scale up/down with the View. Hence, a Model Pattern which is suitable for 1:100 would be not legible at scale 1:200 or 1:500; therefore this behavior:
  1. When they are too dense to display (Because of View Scale) they will turn gray
  2. When they are too dense to be printable ... they turn into a mass gray surface and won't print
Reducing Line weight for that scale can slightly reduce that effect but will not cancel it
