I am trying to show the wall stud hatch as grey in plan and white in section views. Here is the challenge, I can easily set up a view template override for my sections that changes the wall hatch to white. The problem is, I still want to be able to see the plywood and gyp hatches.
The template overrides don't allow a material override just wall overrides.
I also checked under the material. I can change the cut pattern and the surface pattern but that isn't plan or section specific.
Any ideas on a material override that is view specific?
