Material Library Not Showing Up
9 ANTWORTEN 9
Nachricht 1 von 10
1095 Aufrufe, 9 Antworten
Hi There,
I have recently installed Revit 2015. The material library was working completly fine but then out of nowhere, I am now unable to edit a materials appearance. When I open a new page, this error shows.
"Rendering library has not been installed, so the third party geometry cannot be created."
I have read some forums to try solve it but havnt seem to have worked. I have reinstalled it but still no luck.
When I look at my programs under the control panel on my windows, it shows my revit applications as a coloured Icon, but the 4 material librarys as a grey.
Please se attached images.
Can some one please help me.
9 ANTWORTEN 9
Nachricht 2 von 10
jitu1dange
als Antwort auf: Anonymous
It happens when you install Revit without internet connection or your internet connection is to slow to download the material library and Revit components. This can be fixed by downloading the material library for the appropriate version from the Virtual Agent. Or you can go to add or remove program select Revit and select Reinstall make sure your are connected to the internet with decent internet speed other wise it wont download the Revit components and material library and would just show it in the installed programs.
I hope this helps.
Nachricht 3 von 10
jitu1dange
I hope this helps.
Nachricht 4 von 10
ennujozlagam
@Anonymoushello, you can check it HERE. thanks
Nachricht 5 von 10
ennujozlagam
als Antwort auf: jitu1dange
@jitu1dange Hello, I really don't understand on why do you need to post your answers 2X most of your replies? Please give some considerations to this public forum. thanks
Nachricht 6 von 10
jitu1dange
als Antwort auf: ennujozlagam
Hi, Even I don't want to post my comment 2 times, but some times it doesn't get post probably due to inconsistent internet connection, so I press reply button two time. It usually happens in Internet Explorer, but when I see I posted two comments I try to delete one of them but sadly there is no option to do so. I hope you can understand. Sorry for any annoyance I caused.
Nachricht 7 von 10
"LIFE is the most difficult exam, many people fail because they try to copy others, not realizing that everyone has a different question paper....."
What the heck are you talking about??
This is a forum for asking and answering questions, and often those questions can be answered using someone else's solution. In a complicated program like Maya and Max, we figure things out all day long, and so it's nice to get a little bit of help sometimes from someone who has faced a similar difficulty.
Nachricht 8 von 10
That is an inspirational quote he uses as his embedded signatute.  The format of a message does not differentiate the message body from the signature so it can be confusing sometime.
Nachricht 9 von 10
mpeperkamp
Hi @Anonymous,
The following link will help you how to add the content libraries.
Content libraries
If there any questions about it let it now.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Nachricht 10 von 10
ennujozlagam
@Anonymous ....what is your problem????
this is my inspirational quote embedded in my signature AND NOTHING TO DO WITH YOU.  "MYOB"
