Material layer grapic representation gets solid when cutting with void
3 REPLIES 3
benschilders
330 Views, 3 Replies
Hi all,
We have a problem that occurs from time to time when cutting floors or roofs with voids (in place model).
Problem: (added a video of the problem)
When cutting a roof with a model in place void sometimes the layer representation on sections goes crazy
representing it as a solid instead of layers roof/floor.
(the material gets chosen by the category material that is set in object styles)
Sometimes it helps to leave 1mm of a certain layer intact (not cutting it with the void).
(For example, when cutting insulation at the sides of a roof leave 1mm of insulation
then this problem does not occur).
Does anyone had this happen before and maybe found a soulution/work arround ?
(better then to figure out where to leave 1mm of material intact for it to represent as layers)
PS:
I did search the forums for a soulution but couldnt find anyone with similar problems,
if you do know a forum with a soulution feel to link it here.
Kind regards,
Ben
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Tags (3)
3 REPLIES 3
in reply to: benschilders
Try changing one of the Layers in the Assembly to Variable.  The Structure one.
Join geometry the walls with a mass then hide the mass.
benschilders
@barthbradley  Thanks ! , In my case this did the job ! So will remember this one for the future.
@ToanDN  Thanks, i will remember this as a last resort option.
                    I guess one would have to use a filter or subcategories to hide the mass for
                    the most practical use case of this soulution.
Thanks to both of you for sharing your knowlegde
