One of my students asks why the material in this credenza appears correctly in all 3D views in all visual styles (Shaded, Consistent Color, Realistic, Ray Trace, and rendered), but appears white from all directions in all 2D elevations and sections (ditto). I've drilled down through the two levels of nested families and there are no painted surfaces, masking regions, or similar monkeyshines.
I've attached the family. You'll need to supply an image for the material: Herman Miller - Veneer 40 Dark Brown Walnut
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
The family has detail element used for the elevation view. The drawer geometry is set to not be visible in a projected elevation view, and uses detail lines instead.
The drawers are in a nested family so that is where the change needs to happen.
