Wondering how to fix this. The material image is cut up and has a line going through it which i believe the image needs to be resized but im wondering if someone know how to fix it.
Gelöst! Gehe zur Lösung
Gelöst von RC_RVT. Gehe zur Lösung
if you don't want the image repeating then set the repeat to "none". If you are finding that when applying this material to your object the position is wrong, then you may need to amend the position of the image using the "Offset" features under the Texture editor.
