Material - How to change size of perforated holes?
4 ANTWORTEN 4
Nachricht 1 von 5
Marcus.Isacsson
1121 Aufrufe, 4 Antworten
Hi fellas!
We have a problem with perforated holes as a glass foil, where the parameter for "center spacing" doesn't seem to work? (see pictures below)
How would you guys accomplish those holes instead?
Version: Revit 2018.2
4 ANTWORTEN 4
Nachricht 2 von 5
Kimtaurus
als Antwort auf: Marcus.Isacsson
There seems to be a realtion between "Diameter" and "Center Spacing", but when you change Center Spacing not much changes.
I suggest you try to make the cut out with a png file (Type : Custom).
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 5
Marcus.Isacsson
als Antwort auf: Kimtaurus
Exactly, seems that the parameter is broken?
How do you create those cutouts in a png-file?
Just a transparant background?
Nachricht 4 von 5
Kimtaurus
A black and white image should do, but transparant might work as well.
https://lpcetraprojects.wordpress.com/2013/10/12/understanding-autodesk-revit-materials-cadalyst/
Nachricht 5 von 5
Seems like most of the procedural functions in Revit material settings are half-baked.
