I have come upon a (probable) glitch in Revit that I can not rectify. I have included a screencast of the issue.
You will see that there are two instances of an identical family. The one on the right has a clearance zone on the back that is a transparent red (as it should be) and the one on the left has a grey opaque clearance zone. This family does not have an instance parameter for the clearance zone and neither of them have instance graphical overrides. If I copy the grey one, the new copy will show up correctly. The same thing goes for any new instance of the family.
This is happening to quite a few others families in our project. This issue is not resolved by closing and restarting the project. It is not resolved by creating a new 3D view. I promise you that nothing is wrong with our visibility/graphics and/or object styles as I have gone through them a handful of times before realizing that two identical families were showing up differently.
Any ideas??
Hi @rdeardorff
Can you send us a file to troubleshoot? I can share a private folder if you'd like.
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Are they under the same Phase? Thanks to @barthbradley for pointing it out.
Is the grey one joined with any other element?
Hi @rdeardorff
We wanted to check back in with you on this post. How is everything working out? As mentioned before, I would be happy to take a look if you would like to post a sample file for troubleshooting. Please let us know if further assistance is needed from the community on this post. We are happy to help wherever possible.
Thank you and we look forward to your reply update.
Viveka CD
