hi
I am Create Model in Generic model Family and Load in Project But Don't Parameter By Change Material
Gelöst! Gehe zur Lösung
Gelöst von planner_matlabi. Gehe zur Lösung
Select Model
Select Edtie Family
Select Forms
In Properties
Click on global Parameters in Material
Create Material Parameter
Load in Project
Select Model
Go to Edite type model and Change Material
yes yes
Next Question
I am drawing model By Form But I Wanted Drawing Model by Void Form , also , Should I redraw?
No , Don't Need redraw
Select Model
In Properties
Solid/Void Change to Void
Go to Modify Tap
Select Join and Select Two Model
Please For New Question
Create new Topic
If Solved Problem , Please Select Accept As Solution
