Material Edit Delay
1 ANTWORT 1
Nachricht 1 von 2
mike
208 Aufrufe, 1 Antwort
Material Edit Delay
Desperate.   When my very fast machine is connected to a network the material editor takes 4 minutes to open.  When not connected to a network the material editor opens up immediately.   This happened after the network was reset.  This has happened on two other machines on different networks so I want to know what the relationship is between the material editor and network settings.  The material folders are default local.  Any help would be great.
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: mike
have you try to disconnect and map again to your network and see if helps. thanks
