Material doesnt show in realistic view
pardisomidoo
Message 1 of 9
pardisomidoo
Hi
I have problem with one family which i downloaded from bimobjects. the problem is when i add it in my project it doesn't show material  and just shows gray ( in Fine, although in appearance i can can see image and every thing.
i deleted family and add it again, but it didn't changed anything.  I just tested this family i new Revit project , and there it shows perfectly. I don't know what is problem with my project which I need it.
Replies (8)
Message 2 of 9
Set the view phase filter to show complete.
Message 3 of 9
pardisomidoo
thank your for your answer.  its already on show complete. But it just happens for one family and the other families are ok. This family shows perfect in another Revit project. and I m really curious what problem is with my project. and maybe it happens for another family in future . I want to fix it
Message 4 of 9
Edit the family, rename the material, reload and see.
Message 5 of 9
pardisomidoo
I can not even see any changes in that loaded family in my project even after i change the material. that's weird because i can not even see any changes in override in graphics in view.
Message 6 of 9
pardisomidoo
No unfortunately it did not work. what else can be. it seem after  I load a family in my project it is not able to change anything about the appearance about it.
as you can see in images, when I want to load family , it shows its material correctly, but after being loaded , became gray.
Message 7 of 9
Something is not right here. You said realistic mode then you also said override graphics in view.  Those two don't come together.
Delete the family from the project browser, delete the material from the project material browser, then reload the family.
Message 8 of 9
pardisomidoo
about realistic view and override graphics in view, yes i I meant that I just played with different thing and to see that what happens to object and what it can changes and what not.  If I add that material of family to the wall , it works and it shows on wall. I think its not problem with the material itself, but maybe on my project file. something changes in family after being loaded. I delete the family and the material and again after I load it became gray. This problem appears in some of downloaded families not for all of them. and maybe I have to ignore these families in this project file. 😞 although I like them.
Message 9 of 9
FWIW: Project Materials rule. If you have Material named "Red" in the Family that is red, and a Material named "Red" in the Project that is blue, then Family elements that use "Red" will display in the Project as blue.
