Material doesn't apply
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
kalktika
284 Aufrufe, 2 Antworten
 Even though I chose a material for topography it doesn't show up in 3d .Can someone help ?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: kalktika
@kalktika
Change view to Realistic
What you see under the Material Appearance tab and the image you define therein is the Rendered look of the material. Hence, for performance purposes you work in hidden lines or consistent colors mode and when you need the rendered look you switch to realistic mode or you render it
Nachricht 3 von 3
constantin.stroescu
As long as you are in Hidden Mode Graphic Display you are not able to see the material as Appearance ( it will be settings from Graphics)
Turn the Graphic Display to Realistic and/.or Render the view
Constantin Stroescu
