Material display issues with phasing
5 ANTWORTEN 5
Nachricht 1 von 6
pietro
1221 Aufrufe, 5 Antworten
Hi all,
I am trying to set up a new project for a renovation job I am doing and I am having issues with the display in elevations and 3d views.
I have set up phasing and i  have gotten it all working well in plan view but when i go to elevation ( or 3d ) view i am having the following issues :
-  New Curtain walls , windows and doors placed in existing walls are coming up as infill brick patten (can't see window or doors). - Note: These elements show fine when new in new wal;l or existing in existing wall.
I have looked all over trying to find an answer for this but have been unable to find one( sorry if its a stupid question!!)
I assume it has something to do with phasing and phasing settings but it seems these settings/overrides  only control floor plans ??
I have attached an elevation view where i have put in all types of elements to show you how it isn't working and i have marked up this view to point out my issues.
Thanks alot for everyones help!!
I am also not sure how to change the settings so the brick pattern shows on both new and existing walls or so it doesn't show at all??
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
martin.saradin
als Antwort auf: pietro
Hi pietro,
I cannot see your attachment, but did you set up phasing also in view properties?
Nachricht 3 von 6
pietro
als Antwort auf: martin.saradin
Hi Martin,
Sorry my post was taken down and then put back up and the photo was no longer attached, i have re-attached now.
I believe i have set up phasing in view properties
Thanks a lot for your reply. .
Nachricht 4 von 6
martijn_pater
Your curtain walls are drawn in the wrong phase, copy paste them in place in a view with the correct phase it should be in.
Nachricht 5 von 6
pietro
als Antwort auf: martijn_pater
Hi , Thanks for your response.
What phase should they be in ?
they are currently   in ;
Phase created : new construction
Phased Demo: None ( i also tried New construction with the same effect)
Nachricht 6 von 6
martijn_pater
The view you are showing is set to Phase 1, so the curtain wall needs to be placed in/copied to phase 1  (or before) to show and ofcourse not be demolished. You've inserted it in a later phase so Revit will create an infill wall in the earlier phases (=to be demolished). edit: nvm that wasn't an image you uploaded, but the views phase as @martin.saradin circled above needs to be set to phase new construction (or later) aswell for it to show, phase filter set to none I suppose.
